--- title: "Keychain Expressions" --- # Keychain Expressions > >
It's possible to perform calculations on data keys. This section documents the various operators and functions that are available. Keychains have their own expression language, which is called a Keychain Expression to separate it from other languages in Ignition. Keychain Expressions are configured by simply utilizing any operators or functions within the "@" characters. Assuming we have a key named "**myKey**" with a value of 10, we can multiple its value by 10 with the following expression: ``` //Expression @myKey * 10@ //Output 100 ``` Again, note that the "*" operator and multiplier are enclosed in the "@" characters. Of course, we can also use a different key as the multiplier. Assuming we have another key named "**myMultiplier**" that has a value of 5: ``` //Expression @myKey * myMultiplier@ //Output 50 ``` Any characters outside of the "@" characters are not part of the expression, so you can easily add prefixes and suffixes with static text. ``` //Expression Total: @myKey * myMultiplier@ gal //Output Total: 50 gal ``` Additionally, you can utilize separate Keychain Expressions in the same TextShape. Note that "**myUnits**" (which has a string value of "**gal**") is enclosed in a separate set of "@" characters, since it is a separate expression: ``` //Expression Total: @myKey * myMultiplier@ @myUnits@ //Output Total: 50 gal ``` ### Dynamic Data Key Expressions Keychain Expressions may also be used with Dynamic Data Keys. The syntax and operators work exactly the same, except there is no need to type the "@" characters. Because of this, the entire field is treated as a single keychain expression. ![Dynamic Data Key Expressions](dynamic-data-key-expressions.png) ### Conditional Keychain Example The following example demonstrates an if-statement using a Dynamic Data Key. This allows us to highlight different values or ranges contextually, making important values stand out. Assuming a key named "myValue" has been created, and contains a numerical value, we can use the following syntax: ``` #If the value of the "myValue" key is greater than 5, a blue color will be returned. # Otherwise, a green color will be used. myValue>5?"blue":"green" ``` In the image below, the Fill property is also using a dynamic data key, so the Fill Color will be disabled if myValue is less than 1, Blue if myValue is greater than 5, and Green if myValue is between 1 and 5. Note that in the Property inspector, the @ symbols are not needed. ![Conditional Keychain Example](conditional-keychain-example.png) To add more color-value pairs, we simply add more if statements to the end of the expression with a colon: ``` #If the value of "myValue" will determine one of multiple colors: #Greater than 10 will return Red #greater than 5 (but not greater than 10) will return Blue #anything else will return Green. @myValue>10?"red":myValue>5?"blue":"green"@ ``` ## Operators and Functions ### Operators The following operators may be used in a Keychain expression. | Operator | Function | Example | |---|---|---| | Parenthesis | (expr) Nested Expressions | Any portion of a Keychain can be enclosed with parenthesis to guarantee precedence. | | Multiplicative | *, /, % Multiply, divide, modulo | These are the most common and intuitive operators. You might want to display `@quantity*price@` in an invoice line-item or calculate a percent like this `@profit/revenue*100@`. | | Additive | +, - Add, subtract | See multiplicative above | | Relational | >, <, >=, <= Greater-than, less-than, greater/less-than-equal | These are most useful for conditionals: @amount>=0? "Credit" : "Debit"@ or @name=="this"? "that" : name@ | | Equality | ==, != Equal, not-equal | See Relational above | | Logical | AND && | These operators make it possible to test multiple conditions: @revenue>100 && budget<50? "Winner!"@ or @name=="Jack" || name=="Sam"? "Good Name!"@. | | Logical | OR \|\| | See AND above | | Conditional | ? : If/then - with form "expr? true_expr : false_expr" | Provides IF/THEN/ELSE expressions. Note: a false expression is optional. 'null' will be evaluated to false and non-null as true. You can provide null substitutions like this: @name? name : "(None provided)"@. You can also nest conditionals for more conditions. For example, @age>=21?"Adult":(age>12?"Teen":"Child")@. | | Assignments | =, += | For the brave, you can create temporary variables for use in a report. Most of the functionality you might use this for is covered in more intuitive ways (such as the [Running key](data-keys.md#built-in-keys)), but it is possible to define a variable in a header row: @revTotal=0@ and update it in details rows @revTotal+=revenue@. | ### Math Functions The following functions return floats. | Menu Item | Function | |---|---| | floor(float) | Round input down to the nearest whole number. | | ceil(float) | Round input up to the nearest whole number. | | round(float) | Round input to the nearest whole number. | | abs(float) | Returns the absolute value of the input (if number < 0 return number * -1). | | min(float, float) | Returns the input number with the least value. | | max(float, float) | Returns the input number with the greatest value. | | pow(float, float) | Returns first number to the second number power. | ### String Functions The following functions return strings. | Menu Item | Function | |---|---| | startsWith(String, String) | Returns true if the first string starts with the second. | | endsWith(String, String) | Returns true if the first string ends with the second. | | substring(String, int start) | Returns a substring of String beginning at position start. | | join(List aList, String aKeyChain, String aDelimeter) | Used to display an individual attribute of individual objects as a single String. Suppose you have a list of movies and want to show their titles in a comma separated list: @join(getMovies, "getTitle", ", ")@ | | substring(Object aString, int start, int end) | Obtain a subset of a given string. This could be useful if you wanted to restrict a text field to a certain number of chars:@substring(title, 0, 10)@ |
