--- title: "Images and Icons in Perspective" --- # Images and Icons in Perspective >
Perspective supports the import and display of PNG, JPG, JPEG, GIF, and SVG images. Images can be loaded into Perspective using the [Image Management](platform\designer\designer-tools\image-management-tool\image-management-tool.md) tool, dragged and dropped directly into a view, or derived from an external web address. All images are displayed using the [Image](appendix\components\perspective-components\perspective-display-palette\perspective-image\perspective-image.md) component. Similarly, icons can be added to view using the [Icon](appendix\components\perspective-components\perspective-display-palette\perspective-icon\perspective-icon.md) component, or the `icon` property within other select components. Icon paths are selected from a pre-configured library within the Designer, which can be further customized with additional icons as desired. ## Use the Image Management Tool The following example walks through bringing an image from the Image Management tool using an Image component. Note that referencing images from the Image Management tool requires adding "/system/images" to the beginning of the path. 1. Drag an **Image** component onto the view. ![](images-and-icons-in-perspective/2020-12-23_13-41-44.png) 2. At the top of the Designer in the Menu Bar, select **Tools** > **Image Management**. 3. Navigate through the different folders for an image file you want. 4. Right-click on the image and select **Copy Path**. ![](images-and-icons-in-perspective/2020-04-13_09-43-27.png) 5. In the Property Editor, paste the image path into the `source` property for the Image component, making sure to add "/system/images" to the beginning of the path. ![](images-and-icons-in-perspective/2019-03-04_13-10-48.png) The image now appears inside the Image component. ## Drag and Drop an Image onto a View When using the drag and drop method to add an image, you will have the option to upload it into the Image Management tool to be then referenced, or to embed it directly into the view. In this example, we'll pull in a JPG photo of a sunset to use as a background on a home page. Images saved in the Image Management tool can be referenced and used repeatedly as described in the [Using the Image Management Tool](#use-the-image-management-tool) section above. 1. Open a view in the Designer. 2. Locate an image on your computer of an acceptable file type and drag it onto the view. :::note The image in this example has been resized in a graphics editing program to be the size we want. ::: ![](images-and-icons-in-perspective/2019-07-18_13-43-41.png) 3. A Link Image popup will appear for you to select whether you want to save the image as a link (in the Image Management tool) or embed the image. For this example, we will save the image as a link, making sure the **Save and link** option is selected and then clicking **Upload**. Refer to the [Embedding Images](#embedding-images) steps below for selecting **Embed image**. ![](images-and-icons-in-perspective/2019-07-18_13-46-44.png) 4. The image will now appear in the view in an Image component, but the component shape still needs to be adjusted to fit the image size. Drag one of the corner nodes to match the image component border with the full image. ![](images-and-icons-in-perspective/2020-04-10_17-37-15.png) 5. Add any further components and graphics to your view as desired and save your project. For this example, we added a company logo SVG file and navigation buttons. ![](images-and-icons-in-perspective/2019-07-18_15-09-06-b.png) ### Embedding Images Embedded images can degrade performance, but allow you to view and modify image elements directly in the Property Editor. 1. Locate the image on your computer and drag it onto the view. 2. Click the **Embed image** radio button. :::note Large Image File If the image is larger than 100KB, you will see a warning message in the confirmation popup recommending the Save and link option instead. ::: ![](images-and-icons-in-perspective/2019-07-17_10-14-47.png) 3. Click **Embed** to embed the image. 4. Adjust the corner nodes of the Image component border to match the image size. ## Use an External Web Address Images can also be added to the Image component by pasting a copied image address from a web browser into the `source` property. 1. Right-click an image and select **Copy image path**. ![](images-and-icons-in-perspective/url-1.png) 2. In the Designer, drag an **Image** component onto a view. 3. Paste the image address into the `source` field in the Property Editor. ![](images-and-icons-in-perspective/url-2.png) 4. Adjust the corner nodes to display the full image or select a desired fit from the `mode` dropdown. ![](images-and-icons-in-perspective/url-3.png) ## Use Icons Icons in Perspective include a collection of specifically curated Scalable Vector Graphic (SVG) images. The bulk of the icons included with Perspective are derived from the **materials** icon library, which is fully detailed on [Google Fonts - Material Symbols & Icons](https://fonts.google.com/icons), but an **ignition** and **sample-component** folders are also available by default. Icons are referenced using icon paths within Perspective. For example, the path `material/location_on` will reference the `location_on` material design icon. This starting collection of icons can be expanded with custom icon repositories. Icons can be displayed using the following icons: * [Icon](appendix\components\perspective-components\perspective-display-palette\perspective-icon\perspective-icon.md) * [Horizontal Menu](appendix\components\perspective-components\perspective-navigation-palette\perspective-horizontal-menu\perspective-horizontal-menu.md) * [Map](appendix\components\perspective-components\perspective-display-palette\perspective-map\perspective-map.md) * [Accordion](appendix\components\perspective-components\perspective-embedding-palette\perspective-accordion\perspective-accordion.md) All icon properties (via the Icon component or other applicable components) include an interface for selecting both built-in and custom icons from configured libraries. On the right-hand side of the icon path, the Browse ![](images-and-icons-in-perspective/image-2022-12-21_10-29-10.png) icon can be used to search for available icons. The icons will be arranged into headings based on the originating icon files on the Gateway. ![](images-and-icons-in-perspective/image2021-5-11_16-51-2.png) ### Add a Custom Icon Repository Although the built-in icon repository is a great source for icons, you can set up a custom library of icons to be accessible by Ignition. All icon repositories are stored as SVG files within the Gateway's installation directory. A typical path to an icon file will look like: **Windows** ``` C:\Program Files\Inductive Automation\Ignition\data\config\resources\core\com.inductiveautomation.perspective\icons\.svg ``` **MacOS** ``` /usr/local/ignition/data/config/resources/core/com.inductiveautomation.perspective/icons/.svg ``` **Linux** ``` /usr/local/bin/ignition/data/config/resources/core/com.inductiveautomation.perspective/icons/.svg ``` You can create custom libraries by adding your own SVG file at this path. The properties inside the file are defined using XML, which should follow the pattern provided below. Note that each icon is placed in an enclosing SVG tag that defines values for both the **id** attribute, which is used to specify the name of each icon, and the **viewbox** attribute, which must have large enough dimensions to fully enclose the graphic. ```xml ``` A Designer restart is required once an icon file has been added to pull in the new icons for development. #### Custom Icon Repository Example In this example, we'll make a custom repository file with icons. The name of the file is `example.svg`. We'll then use the icons in this file and other repositories to create a Horizontal Menu component for Proposal, Project Documents, and Appendix headings. ![](images-and-icons-in-perspective/2020-04-13_11-33-29.png) 1. Begin by creating the repository file in xml. ```xml ``` 2. Save the file in the Ignition directory: ``` C:\Program Files\Inductive Automation\Ignition\data\config\resources\core\com.inductiveautomation.perspective\icons ``` 3. You will also need to create both a `config.json` and `resource.json` file within the same directory as `example.svg`. The `config.json` file should have a single entry that contains the same name as your .svg file: ```json { "svgFileName": "example.svg" } ``` 4. The `resource.json` file should reference both `config.json` and `example.svg`, and contain several other items: ```json { "scope": "A", "version": 1, "restricted": false, "overridable": true, "files": [ "config.json", "example.svg" ], "attributes": { } } ``` 5. After creating these files, we will need to restart our Designer and Gateway for the changes to be recognized. If you want to avoid restarting your Gateway, you can use the **Scan File System** button found on the top right of the Gateway's **Platform Overview** page to pull in your file changes. 6. Now we can use the icons in this icon repository for our components. For this example, we put a Horizontal Menu component in a Coordinate view. 7. We will use two icons from the new example repository and one from the materials repository. We will set the properties as follows for the Horizontal Menu component: **Top Level Properties** | Property | Value | | ------------------------------ | ----------------------- | | props.items.0.enabled | TRUE | | props.items.0.icon.path | example/one | | props.items.0.icon.color | #4747FF | | props.items.0.label | Proposal | | props.items.0.style.color | #4747FF | | props.items.0.style.fontFamily | Verdana | | props.items.1.enabled | TRUE | | props.items.1.icon | example/two | | props.items.1.color | #008000 | | props.items.1.label | Project Documents | | props.items.1.style.color | #008000 | | props.items.1.style.fontFamily | Verdana | | props.items.2.enabled | TRUE | | props.items.2.icon.path | material/folder_special | | props.items.2.icon.color | #AC00AC | | props.items.2.label | Appendix | | props.items.2.style.color | #AC00AC | | props.items.2.style.fontFamily | Verdana | | props.style.borderBottomStyle | double | | props.style.borderLeftStyle | none | | props.style.borderRightStyle | none | | props.style.borderTopStyle | double | | props.style.borderTopWidth | 4 | | props.style.borderBottomWidth | 4 | 8. Enable the Designer Preview ![]() mode to see the Horizontal Menu appearance. ![](images-and-icons-in-perspective/2020-04-13_11-33-29.png) ## Convert SVG-based Components to Drawings Right-clicking an SVG-based Perspective component will show a Convert to Drawing option. Converting the component to a drawing transforms the component's properties. For example, the Cylindrical Tank component props list changes to include properties like viewBox, preserveAspectRatio, and elements. ![](images-and-icons-in-perspective/image2022-10-3_13-48-57.png) |Component Example| Properties|Property Editor Image| |--|--|--| |Cylindrical Tank as a Component |valuecapacityliquidColortankColorliquidOpacityliquidWarningColortankWarningColorwarningThresholdstrokeWidthvalueDisplayenabledstylestyle|![](images-and-icons-in-perspective/image2022-10-3_13-52-20.png) | |Cylindrical Tank as a Drawing|viewBoxpreserveAspectRatioelements12345style |![](images-and-icons-in-perspective/image2022-10-3_13-53-3.png)|
