--- title: "Connecting to PLC5" --- # Connecting to PLC5 > :::note > This driver supports PLC-5 processors using either Ethernet/IP or CSP over TCP/IP. > ::: ## Connect to a PLC-5 Device This driver requires the OPC UA module to be installed and enabled. If the module is missing or disabled, the device will fault with a “Missing Dependency” error on the **Platform** **System** > **Modules** page. 1. On the Gateway, go to **Connections** > **Devices** > **Connections**. ![](../../devices-connections.png) 2. Click **Create Device Connection +**. 3. Select **Allen-Bradley PLC5** and click **Next**. ![](select-plc5.png) 4. On the **Configure Device** screen, enter the required fields: * **Name**: PLC5 * **Hostname**: The IP address of the PLC5 (e.g., 10.20.4.56) ![](plc5-settings.png) 5. Click **Create Device Connection**. The device will be listed now on the Connections page. The status will initially show Disconnected, but will move to a Connected state. ![](plc5-connected.png) ## Device Connection Settings ### General | Name | Description | |------|-------------| | Name | A user-defined name for the device. This name appears in OPC item paths and the Devices list. Name must begin with an underscore or a letter, and cannot include special characters. | | Description | Optional description to help identify the device. | | Enabled | When selected, the device is active and available for use. | ### Connectivity | Name | Description | |------|-------------| | Hostname | The Hostname value is the IP Address of the PLC-5 processor. The protocol that the PLC-5 processor supports is automatically detected. It will use either CSP protocol on port 2222 (0x8AE) or EthernetIP protocol on port 44818 (0xAF12). | | Local Address | The local address to connect from when establishing a TCP connection. If left blank, then the driver will select an available address. | | Timeout | The maximum amount of time to wait, in milliseconds, for responses from the processor. | | Connection Path | The Connection Path value is used to define the route of the PLC-5 processor to connect to. [Optional] See [Connection Path Format](#connection-path-format) for more details. | ### Advanced | Name | Description | |------|-------------| | Disable Processor Browse | Disables processor browse setting. | | Zero TNS Connection | Disables the Zero TNS connection setting. | | Browse Cache Timeout | The amount of time, in milliseconds, to cache tag structure results read from the device. | ## Connection Path Format The [Connection Path](ignition-modules/opc-ua/opc-ua-drivers/allen-bradley-ethernet/allen-bradley-connection-paths/allen-bradley-connection-paths.md) is used when routing to a PLC5 via ControlLogix hardware, such as a 1756-DHRIO module. Use the following format: `1,,,` * **1**: Instructs the 1756-ENET module to move to the backplane * **DHRIO slot number**: Slot of the 1756-DHRIO module (0–16 depending on the chassis size) * **DHRIO channel**: Use 2 for Channel A, or 3 for Channel B * **DH+ node number**: The node number configured in the PLC-5 (octal, range 00–77) ### Supported PLC5 Connection Methods * PLC-5 L/20E, L/40E, and L/80E via Ethernet/IP * Any PLC-5 processor connected over DH+ through a 1756-DHRIO module :::note ASCII data types from PLC-5 devices are not supported by the PLC5 driver. :::
