--- title: "Connecting to MicroLogix" --- # Connecting to MicroLogix > >
This driver supports: * MicroLogix 1100 and 1400 direct over Ethernet/IP * MicroLogix 1100 and 1400 through a 1761-NET-ENI Ethernet interface * MicroLogix 1100 and 1400 through a Spectrum Controls WebPort 500 :::caution MicroLogix 1200 and 1500 are not fully supported. These devices do not support tag browsing, so **Disable Processor Browse** must be enabled. Additionally, the MicroLogix driver does not support access to Input Parameters. ::: ## Connect to a MicroLogix Device This driver requires the OPC UA module to be installed and enabled. If the module is missing or disabled, the device will fault with a “Missing Dependency” error on the **Platform** **System** > **Modules** page. 1. On the Gateway, go to **Connections** > **Devices** > **Connections**. ![](../../devices-connections.png) 2. Click **Create Device Connection +**. 3. Select **Allen-Bradley MicroLogix** and click **Next**. ![](select-micrologix.png) 4. On the **Configure Device** screen, enter the required fields: * **Name**: MicroLogix * **Hostname**: The IP address of the device (e.g., 10.20.7.77) ![](micrologix-settings.png) 5. Click **Create Device Connection**. The device will be listed now on the Connections page. The status will initially show Disconnected, but will move to a Connected state. ![](micrologix-connected.png) ## Device Connection Settings ### General | Name | Description | |------|-------------| | Name | A user-defined name for the device. This name appears in OPC item paths and the Devices list. Name must begin with an underscore or a letter, and cannot include special characters. | | Description | Optional description to help identify the device. | | Enabled | When selected, the device is active and available for use. | ### Connectivity | Name | Description | |------|-------------| | Hostname | The Hostname value is the IP Address of the MicroLogix 1100 processor, MicroLogix 1400 processor or 1761-NET-ENI Ethernet interface. EthernetIP protocol on TCP port 44818 (0xAF12) is used to communicate to the listed devices. | | Local Address | The local address to connect from when establishing a TCP connection. If left blank, then the driver will select an available address. | | Timeout | The maximum amount of time to wait, in milliseconds, for responses from the processor. | | Connection Path | The connection path to the processor. If specified, the slot number setting is ignored, so be sure to terminate the path with backplane and slot number. [Optional] **Note**: If a MicroLogix device becomes stuck in a Browse Pending state, try setting this property to `1,0` to force routing through backplane slot 0.| ### Advanced | Name | Description | |------|-------------| | Disable Processor Browse | Disables processor browse setting. May be required for some MicroLogix 1200 or 1500 devices. | | Zero TNS Connection | Disables the Zero TNS connection setting. | | Browse Cache Timeout | The amount of time, in milliseconds, to cache tag structure results read from the device. |
