--- title: "Connecting to Logix" --- # Connecting to Logix > :::note > This driver is optimized for Logix family devices with firmware version 21+, but supports earlier firmware versions with significantly reduced performance. > ::: ## Connect to a Logix Device This driver requires the OPC UA module to be installed and enabled. If the module is missing or disabled, the device will fault with a “Missing Dependency” error on the **Platform** **System** > **Modules** page. 1. On the Gateway, go to **Connections** > **Devices** > **Connections**. ![](../../devices-connections.png) 2. Click **Create Device Connection +**. 3. Select **Allen-Bradley Logix Driver** and click **Next**. ![](select-logix.png) 4. On the **Configure Device** screen, enter the required fields: * **Name**: LGX * **Hostname**: The IP address of the PLC (e.g., 10.20.1.54) ![](logix-settings.png) 5. Click **Create Device Connection**. The device will be listed now on the Connections page. The status will initially show Disconnected, but will move to a Connected state. ![](logix-connected.png) ## Driver Implementation This driver maps boolean arrays as members of 32-bit DWORDs. For example, a **BOOL[64]** in the PLC is represented as a **DWORD[2]** in Ignition. Below is a table representing how members of a boolean array items are mapped in the PLC, compared to the Logix driver's implementation. | PLC Mapping | Driver Implementation | |---------------|------------------------| | boolTag[0] | boolTag[0].0 | | boolTag[31] | boolTag[0].31 | | boolTag[32] | boolTag[1].0 | | boolTag[63] | boolTag[1].31 | The Logix driver also supports the following data types: * DT (Date/Time) * LDT (Date/Time [ns]) * LTIME (LTime [ns]) * TIME (Decimal) * TIME32 (Time32 [µs]) ## Device Connection Settings ### General | Name | Description | |------|-------------| | Name | A user-defined name for the device. This name appears in OPC item paths and the Devices list. Name must begin with an underscore or a letter, and cannot include special characters. | | Description | Optional description to help identify the device. | | Enabled | When selected, the device is active and available for use. | ### Connectivity | Name | Description | |------|-------------| | Hostname | This is the IP address of the ControlLogix Ethernet module (1756-ENET) to route through to connect a ControlLogix processor. EthernetIP protocol on TCP port 44818 (0xAF12) is used to communicate to ControlLogix processors. | | Port | TCP port used for communication. The default is 44818. | | Local Address | The local address to connect from when establishing a TCP connection. If left blank, then the driver will simply pick an available address. | | Timeout | The maximum amount of time to wait, in milliseconds, for responses from the processor. | | Connection Path | If specified, the slot number setting is ignored for this connection path to the processor. Be sure to terminate the path with backplane and slot number. | ### Advanced | Name | Description | |------|-------------| | Automatic Rebrowse | When enabled, detects new tags and UDT changes and rebrowses automatically. | | Identity Request Frequency | Frequency, in milliseconds, to request CIP Identity Object attributes. | | CIP Connection Size | Size used in CIP Forward Open requests. | | CIP Connection Timeout | Timeout, in milliseconds, for CIP connections and RPI. | | Slot Number | The slot in which the processor resides. If not in a rack, use 0. | | Max Concurrent Requests | Number of concurrent requests sent to the device. Increasing this may improve throughput but could overwhelm the processor. |
