--- title: "Connecting to ControlLogix" --- # Connecting to ControlLogix > :::note > This driver supports ControlLogix firmware up to version 20.18. > ::: ## Connect to a ControlLogix Device This driver requires the OPC UA module to be installed and enabled. If the module is missing or disabled, the device will fault with a “Missing Dependency” error on the **Platform** **System** > **Modules** page. 1. On the Gateway, go to **Connections** > **Devices** > **Connections**. ![](../../devices-connections.png) 2. Click **Create Device Connection +**. 3. Select **Allen-Bradley ControlLogix (Legacy)** and click **Next**. ![](select-controllogix.png) 4. On the **Configure Device** screen, enter the required fields: * **Name**: CLX * **Hostname**: The IP address of the PLC (e.g., 10.20.4.50) ![](controllogix-settings.png) 5. Click **Create Device Connection**. The device will be listed now on the Connections page. The status will initially show Disconnected, but will move to a Connected state. ![](controllogix-connected.png) ## Device Connection Settings ### General | Name | Description | |------|-------------| | Name | A user-defined name for the device. This name appears in OPC item paths and the Devices list. Name must begin with an underscore or a letter, and cannot include special characters. | | Description | An optional description to help identify the device. | | Enabled | When selected, the device is active and available for use in the system. | ### Connectivity | Name | Description | |------|-------------| | Hostname | IP address of the Ethernet module (e.g., 1756-ENET) used to connect to the ControlLogix processor. | | Local Address | IP address of the local network adapter to bind to. Leave blank to auto-select. | | Timeout | Timeout in milliseconds for a request to receive a response from the device. | | Connection Path | Used to define a route to the ControlLogix or downstream PLC-5 processor. See [Allen-Bradley Connection Paths](../allen-bradley-ethernet.md#allen-bradley-connection-paths) for more information. | ### Advanced | Name | Description | |------|-------------| | Disable Automatic Browse | Disables automatic browsing of the tag tree. | | Show String Arrays | Displays string arrays from the device if supported. | | Status Request Poll Rate | Frequency in milliseconds for polling the device status. | | Slot Number | The zero-based slot number of the ControlLogix processor in the chassis. | | Max Concurrent Requests | Number of simultaneous requests the driver sends to the device. Higher values may improve throughput but can overload the PLC. | ### Supported Connection Methods This driver supports ControlLogix 5500 devices connected through a 1756-ENET/A or 1756-ENET/B module. ### Considerations for ControlLogix Settings When the ControlLogix processor **External Access** setting for a tag is set to `None`, the tag information is not returned to Ignition during reading of tag information. Using RSLogix 5000, change the External Access setting to either `Read Only` or `Read/Write` for the tag to show in the Ignition browse results. ![](external-access.png)
