--- title: "Agent Task - Send Project" --- # Agent Task - Send Project > >
Agent Tasks have the ability to send projects and project resources from a controller to an agent. This includes sending projects and project resources across major Ignition platform versions, such as a controller on 8.1 sending a project to an agent on 8.3. It is also possible to send project resources from agent to agent if needed. However, some resources, such as Gateway and Perspective Event Scripts, cannot be sent from an 8.3 controller to an 8.1 agent. :::caution Sending Project Resources to Edge Gateways If attempting to send project resources to one or more Edge Gateways, you must select only Edge Gateways for the agent location setting. Selecting a combination of Edge and Standard Edition Gateways will result in no resources being received. ::: ## Send Project Task The Send Project task will not only send a project from the controller to the agent, but if the project already exists on the agent, it will replace it. 1. On the controller Gateway, under the **Network** section of the Gateway webpage, go to **Enterprise** > **Agent Tasks**. 2. Click **Create Agent Task**. ![](2020-03-11_13-36-02.png) 3. Scroll down and select **Send Project**. Click **Next**. ![](2020-03-11_16-53-27.png) 4. Just like with any Agent Task, the Send Project task needs to be scheduled. There are several scheduling options available, but for this example, schedule the task to **Execute Immediately** and click **Next**. 5. Select the agent where you want to send your project and click **Next**. 6. The Create Agent Task form knows your controller and agent configuration. It’s going to prompt you to choose the machine where your project is located. In this example, the project that you want to send is located on the controller or Gateway Source so select **Local System** and click **Next**. ![](2020-03-11_17-04-37.png) 7. The Create Agent Task form will display all your projects from your local system. Select the project you want to send to your agent, and click **Next**. Note that if you selected your agent in the previous step, the Create Agent Task form will display all your projects running on your agent that were sent over previously from the controller. 8. Confirm the Max Concurrent Agents setting, which helps in situations where network connections are weak or bandwidth is limited. For this example, we will leave the value at the default of 0, which disables the setting. ![](image-2023-5-3_13-5-56.png) 9. Review your task information and click **Create Agent Task**. ![](image-2023-5-3_13-8-9.png) Your project will be sent from the controller Gateway to the agent Gateway, the screen will refresh, and a message will pop up stating that your Send Project task was successful. To verify that your project was sent, go to your agent Gateway, click **Platform**, and select **System** > **Projects**. ### Inherited Resources An option for the Send Project task to include inherited resources is also available when sending a project from the controller to an agent. If checked, the selected project and any inherited resources will be combined into a single project on the target agents. A checkbox was added to the Agent Tasks, as shown in the image below, to include inherited project resources. The default is false. ![](19-03-21-12-33-55.png) ## Send Project Resources Task You can also send project resources, such as project templates, windows, transaction groups, pipelines and even script modules from the controller to an agent. ### Sending Global Resources Global Resources may now be sent with the Send Project Resources Task. Resources such as Shared Scripts and Alarm Pipelines may be sent to any agent. When selecting a destination project, Global resources may only be sent to the "Global project" on the agent. ### Sending Project Resources Example On the controller Gateway, under the **Network** section of the Gateway Webpage, go to **Enterprise** > **Agent Tasks**. Let’s create another Gateway Task to send project resources from the controller to the agent. 1. Click **Create Agent Task**. 2. Select **Send Project Resources** and click Next. ![](2020-03-11_17-19-19.png) 3. Schedule the Send Project Resources task to **Execute Immediately** and click **Next**. 4. Select the agent on the Agent Selection window and click **Next**. 5. Select the Source Gateway as **Local System** where your project resources reside and click **Next**. 6. Select the project you want to send resources from and click **Next**. 7. You can see all the resources inside of the selected project. It may include templates, windows, transaction groups, pipelines, and script modules. Choose the resources you want to send to the agent and click **Next**. ![](2020-03-11_17-25-18.png) 8. You have the option of either merging the project resources into an existing project or creating a new project on the agent. In this example, let's create a new project. Select **Other** and enter a new project name. Click **Next**. 9. Enter a Max Concurrent Agents value to limit the number of agents that will be concurrently contacted as the task executes, which helps in situations where network connections are weak or bandwidth is limited. For this example, we will leave the value at the default of 0, which disables the setting, then click **Next**. ![](image-2023-5-3_13-5-56.png) 10. Review the task information summary. Click **Create Agent Task**. The screen will refresh and a message will appear stating that the task was successful. 11. To verify that the Training project resources were sent, go to your agent Gateway, click on the **Platform** tab and select **System** > **Projects**. You can see in this example that a new project was created by the EAM controller. Once your project and project resources are sent to the agent, you need to complete the installation of your project. You need to set up your authentication profile, database, and Tag Providers. Once this is completed, you are ready to use the project and project resources on your agent.
