Version: 8.3
Twilio WhatsApp Notification
💡Have feedback for this page? Let us know on the IA Forum.
WhatsApp SMS notifications can be sent with the Twilio Notification module. This profile does not require a cellular modem, but the Gateway must have Internet access and a Twilio account with SMS capabilities must be created (www.twilio.com). The Twilio account must then also be defined in Ignition.
caution
The Alarm Notification module must be installed and enabled. If the Alarm Notification module is not installed or is disabled, a warning will appear in the logs and display the state as "Faulted Missing Dependency" on the Platform > System > Modules page.
See the system.twilio section of the appendix for details on the two scripting functions available for the Twilio WhatsApp Notification Profile.
Message Types​
WhatsApp allows two types of messages, template and free-form. Upon initial communication, Twilio can only send these pre-approved template messages.
  • Template Messages: Template messages are configurable messages on Twilio that can be sent to users via Twilio WhatsApp. Templates are generic messages, but parameters allow templates to be a bit more versatile. Template Parameters are entered in the Notification Block settings in the Designer. Refer to the WhatsApp Message Template Overview for more information on template messages.
  • Free-Form Messages: Any message that is not a pre-approved template message is considered free-form. You can configure your free-form messages using the Message field on the alarm or on the alarm Notification block.
The only way to send free-form SMS messages in WhatsApp is for the user to respond to a template in order to open a 24-hour messaging session. Once a user replies to a template message, then the alarm notifications will send out the configured free-form messages. The 24-hour Session will remain open for 24 hours from the last message received from the user.
Create a Twilio WhatsApp Notification Profile​
  1. Go to the Services section of the Gateway Webpage.
  2. Select Alarming > Notification from the menu on the left side.
  3. Click on Create Profile +.
  4. Select the WhatsApp SMS Notification profile type, and click Next.
  5. Provide a name for the profile, and select a Twilio Account from the dropdown.
  6. Set the other profile settings as desired. See table below for a description of all settings.
  7. Click Create Alarm Notification Profile.
Once your Notification profile is created, you can use it in an Alarm Pipeline. Note that your user contact information needs to be set to WhatsApp SMS to receive messages.
Twilio WhatsApp Notification Profile Settings​
The following table describes the settings on the Alarm Notification Profiles page for a Twilio WhatsApp Notification profile.
General​
SettingDescription
NameName for this alarm notification profile.
DescriptionDescription of the profile.
EnabledWhether the profile is enabled or disabled.
Twilio​
SettingDescription
Twilio AccountSelect a Twilio account from the dropdown list.
Acknowledgement AllowedEnables users to respond to notifications directly from the SMS message; also known as Two-Way notification. If enabled, the Public Hostname property in the Twilio Account must be configured.
Auditing​
SettingDescription
Auditing ProfileSelect an audit profile from the dropdown list.
WhatsApp​
SettingDescription
WhatsApp Service SIDTwilio's messaging service ID, found on Twilio's Console when navigating under Develop > Messaging > Services.
