title: "Twilio Voice Notification"
# Twilio Voice Notification
Voice notifications can be sent with the [Twilio Notification module](getting-started/modules-overview/additional-modules/twilio-alarm-notification.md). To function, the Gateway must have Internet access and a Twilio account (www.twilio.com) with voice capabilities [defined in Ignition](../twilio-notification-profiles.md#define-a-twilio-account). This profile allows you to configure a custom message associated with the alarm using the Alarm Notification Pipeline via an automated phone call when an alarm is triggered. The alarm can optionally be acknowledged through the phone call.
## Prerequisites
When defining your Twilio account in Ignition, you'll already have noted your Account SID and Auth Token, but more settings are required for voice notification to function successfully. Alongside the SID and token, you'll also want to confirm the number listed in the My Twilio phone number field, as this is the from number where Twilio calls will originate once our notifications are set up in Ignition. Finally, make sure your Twilio Markup Language or [TwiML app](https://www.twilio.com/docs/voice/twiml) includes accurate Voice Configuration properties, like the [Request URL and Status Callback URL](https://www.twilio.com/docs/voice/api/sending-sip#request-url-webhook) webhooks so the Twilio service knows how to handle incoming calls and messages.
These URLs need to end with `/data/twilio/voice/message`. Navigate to your Twilio account **Phone Numbers** > **Manage** > **TwiML apps** page to update or add these properties.
Once all the required configuration is complete on the Twilio side, you can get started with creating a Twilio Voice Notification Profile.
:::caution
This module requires the Alarm Notification module to be installed and enabled. If the Alarm Notification module is not installed or is disabled, this module will fault with a warning in the logs and display the state as "Faulted Missing Dependency" on the **Platform** > **System** > **Modules** page.
## Messaging Configurations
Notification profile settings include enabling acknowledgement, pin validation, broadcasting notification calls to all users, and recording calls. Additionally, the language and text-to-speech voice to use for generating calls are selected when creating or editing the notification profile.
The Twilio module adds a User PIN field to user profiles, which is where the pin validation value used to authenticate users is pulled from. When enabled, validation is required before the user can read alarm information or acknowledge the alarm. When acknowledgement is enabled, the call will ask users if they want to acknowledge or ignore an alarm, and if the user selects acknowledge, the alarm state is changed to acknowledged.
If you choose to enable broadcasting, the voice message is sent to all users on the assigned roster at once. When broadcast notifications are used, the above PIN authentication and alarm acknowledgement settings are ignored. This means that broadcasted calls are unauthenticated by default, even as they might contain sensitive alarm information.
It's also important to be aware that when recording calls is enabled, the recording is stored and accessible in the Twilio dashboard. Recorded calls can be accessed in the Twilio dashboard after they are recorded. Select an auditing profile from the setting dropdown on the Voice Notification Profile page to store phone calls and acknowledgements to the audit system.
## Pipeline Configuration
Like all notification methods, the Twilio Voice profile is selected in the Notification Block Editor in the Designer's pipeline configuration. The Twilio Voice profile includes two properties, From Number and Max Pin Attempts.
* From Number: The phone number configured in the Twilio dashboard, from which to send the phone call.
* Max Pin Attempts: The maximum number of attempts allowed for a user to correctly enter a PIN when pin validation is enabled.
The Call Script and Delay Between Messages (seconds) property are also displayed here.
Expanding the Call Script list allows you to customize the alarm message the user hears through a call script text. There are several points where the call may stop to collect user input, so the call script is the list of messages used by the text-to-speech engine to generate the call.
### Call Script Options
The following table is a full list of configurations for the call script, with their respective defaults:
|Configuration|Description|Default|
|Greeting |Introductory message. |Hello, this is an Ignition alarm notification. |
|PIN Challenge |A message asking the user to enter their PIN number. Must instruct them to press '#' when finished. |Please enter your pin, followed by the pound sign. |
|Non-PIN Challenge |When a PIN is not required, this message is played to instruct the users to press any key to continue. |Please press any key to continue. |
|Invalid PIN |A message telling the user their PIN was invalid, and to try again. |Invalid pin number. Please re-enter your pin, followed by the pound sign. |
|Summary | When there are multiple alarms, this message will be played to tell the user how many to expect. It must include the placeholder '%d' somewhere in the message.|There are %d events. |
|Active Message |The message to play for active alarms. This message can reference properties of alarms by using syntax like `{propertyName}`. |
At `{eventTime`|`hh:mm:ss}`, alarm named `{name}` became `{eventState}` with a value of `{eventValue}` |
|Clear Message |The message to play for cleared alarms. This message can reference properties of alarms by using syntax like `{propertyName}`. |At `{eventTime`|`hh:mm:ss}`, alarm named `{name}` became `{eventState}` with a value of `{eventValue}` |
|Option 1: Acknowledge |Tells the user to press '1' to acknowledge. |Press 1 to acknowledge |
|Acknowledge Confirmation |Tells the user that the alarm event has been successfully acknowledged. |Alarm has been acknowledged. |
|Option 2: Ignore |Tells the user to press '2' to ignore/bypass the alarm. |Press 2 to ignore |
|Ignore Confirmation |Tells the user the alarm event has been ignored. |Alarm has been ignored. |
|Option 3: Repeat |Tells the user to press '3' to repeat the last message. |Press 3 to repeat |
|Closing |Closing message |Thank you, goodbye. |
## Voice Functions
See the [system.twilio](../../../../../appendix/scripting-functions/system-twilio/system-twilio.md) section of the appendix for more details on the `sendPhoneCall` function available for the Twilio Voice Notification Profile.
## Create a Twilio Voice Notification Profile
1. Go to the **Services** section of the Gateway Webpage.
2. Select **Alarming** > **Notification** from the menu on the left side.
3. Click on **Create Profile +**.
4. Select the **Twilio Voice Notification** profile type, and click **Next**.
5. Provide a name for the profile, and select a **Twilio Account** from the dropdown.
6. Set the other profile settings as desired. (See table below for a description of all settings.)
7. Click **Create Alarm Notification Profile**.
Once your Notification profile is created, you can use it in an Alarm Pipeline.
### Twilio Voice Notification Profile Settings
The following table describes the settings on the Alarm Notification Profiles page for a Twilio Voice Notification profile.
#### General
| Setting | Description |
| Name | Name for this alarm notification profile. |
| Description | Description of the profile.|
| Enabled | Whether the profile is enabled or disabled. |
#### Twilio Settings
| Twilio Account | Select a Twilio account from the dropdown list. |
| Allow Acknowledgement | Enables users to respond to notifications directly from the call; also known as **Two-Way notification**. If enabled, the **Public Hostname** property in the Twilio Account must be configured. Default is true. |
| Require PIN Authentication | Whether to authenticate users before alarm summary. Default is true. |
| Broadcast Notifications Enabled |When enabled, all users on the connected on-call roster will be notified. Default is false. **Note**: It is recommended to enable this property if there is no valid [inbound public hostname](ignition-modules\alarm-notification\notification-profile-types\twilio-notification-profiles\twilio-notification-profiles.md#inbound) configured on the Twilio account. |
| Record Calls | Activates Twilio's phone call recording feature. Default is false.|
| Voice | Selects the text-to-speech voice to use.|
| Language | Selects the language to use.|
| Answer Timeout | Sets the amount of time, in seconds, a call is allowed to go unanswered before it's considered failed. Default is 60 seconds.|
| Max Call Duration | Sets the maximum time, in minutes, for a call to last. Default is 5 minutes.|
#### Other
| Auditing Profile | Select an audit profile from the dropdown list. If an audit profile is selected, phone calls and acknowledgements will be stored to the audit system. Note that alarm acknowledgements are also stored to the alarm journal.|
