--- title: "SMS Notification Profile" --- # SMS Notification Profile > >
The SMS Notification Profile allows you to send alarm notifications over a cellular network using a supported AirLink modem. It supports both one-way and two-way SMS communication, including alarm acknowledgments via SMS reply if enabled. This profile is commonly used in remote environments where network access is limited, but cellular coverage is available. ## SMS Notification Module Short Message Service (SMS) is the protocol used by most text messaging systems. The SMS Notification module enables SMS alarm delivery using a cellular modem configured with a valid SIM card. If two-way messaging is enabled, recipients can respond to alarm messages with an acknowledgment code. :::note The SMS Notification module depends on the Alarm Notification module. Both must be installed and running. ::: ### Device Configuration Inductive Automation officially supports the following Sierra Wireless AirLink devices: * RV50 / RV50X * RV55 * LX40 Other modems that support the AirLink IP protocol may also work, but may require additional configuration. Template settings for supported devices are available in the following Knowledge Base Articles: ### Multiple Gateways with One Modem A single AirLink modem can send messages for multiple Ignition systems in one-way (outgoing only) mode. However, only one Gateway should receive incoming SMS responses if two-way messaging is enabled. ## Create an SMS Notification Profile Follow these steps to create an SMS Notification Profile. 1. In the Gateway, go to **Services** > **Alarming** > **Notification**. 2. Click **Create Profile +**. 3. Select **SMS Notification**, then click **Next**. ![Select SMS Notification from profile options](sms-notification.png) :::tip If the profile type is missing, go to **Platform** > **System** > **Modules** to verify that the Alarm Notification module is installed and running. ::: 4. Enter values for your device into the required fields. In this example, we used the following: * **Name**: SMS * **Airlink Host Address**: The IP address of the Airlink modem. * **Send Port**: 17341 * **Receive Port**: 17342 * **Airlink Backup Host Address**: The IP address of the backup Airlink modem. * **Backup Send Port**: 17341 * **Backup Receive Port**: 17342 * **Two-way Enabled**: True ![Configure SMS Notification Profile](sms-setup.png) 5. Click **Create Alarm Notification Profile**. 6. The profile appears in the list and will begin running immediately. You can edit it at any time to modify the modem address, backup ports, or acknowledgment behavior. ![SMS Notification Profile listed with Running status](sms-status-running.png) Once configured, you can assign phone numbers to users using the **SMS** contact type. ## SMS Notification Profile Settings ### Main | Property Name | Description | | ------------- | ----------- | | Name | Name of the notification profile. | | Description | Optional description for the profile. | | Enabled | Whether the profile is currently active. | ### SMS Settings | Property Name | Description | | ------------- | ----------- | | Airlink Host Address | IP address of the primary AirLink modem. | | Send Port | UDP port used to send messages to the modem. Default: `17341`. | | Receive Port | UDP port used to receive alarm acknowledgments from the modem. Default: `17342`. | | Airlink Backup Host Address | IP address of the backup modem used by a redundant Gateway if redundancy is configured. | | Backup Send Port | Send port to use when in backup mode. | | Backup Receive Port | Receive port to use when in backup mode. | | Two-way Enabled | Allows recipients to acknowledge alarms by replying to the SMS. | | Numeric Only Ack Code | Forces acknowledgment codes to be numeric only (instead of alphanumeric). | ### Auditing | Property Name | Description | | ------------- | ----------- | | Audit Profile | Stores SMS message events and acknowledgments in the selected audit profile. Alarm acknowledgments are also written to the Alarm Journal. |
