--- title: "Simple One-Way Email Notification Profile" --- # Simple One-Way Email Notification Profile > The Simple One-Way Email Notification Profile is used to notify users when alarms occur, based on priority level. Unlike the standard Email Notification Profile, this one does not use alarm pipelines and does not include acknowledgment links in the emails. Instead, it listens for active alarms within a specified priority range and sends notifications to a configured [On-Call Roster](ignition-modules/alarm-notification/on-call-rosters/on-call-rosters.md). When the criteria is met, the profile sends alerts to all users in the configured roster. :::note The Simple One-Way Email Notification Profile requires the [Alarm Notification module](getting-started/modules-overview/core-modules/alarm-notification-module.md) to be installed. ::: ## Create a Simple One-Way Email Notification Profile Follow these steps to create a Simple One-Way Email Notification Profile. 1. In the Gateway, go to **Services** > **Alarming** > **Notification**. 2. Click **Create Profile +**. 3. Select **Simple One-Way Email Notification**, then click **Next**. ![Select Simple One-Way Email Notification from profile options](simple-one-way-notification.png) :::tip If the profile type doesn’t appear, verify that the **Alarm Notification module** is installed and running. Go to **Platform** > **System** > **Modules** to confirm. ::: 4. Enter values for your device into the required fields. In this example, we used the following: * **Name**: One-Way Email * **SMTP Profile**: SMTP * **On-Call Roster**: Managers * **Minimum Priority**: High * **Maximum Priority**: Critical ![Configure Simple One-Way Email Notification Profile form showing example values](simple-one-way-setup.png) 5. Click **Create Alarm Notification Profile**. 6. The profile will appear in the list and start running automatically. You can edit it at any time to update the On-Call Roster or alarm priority range. ![Simple One-Way Email Notification Profile listed with a Running status](one-way-status-running.png) ## Simple One-Way Email Notification Profile Settings ### Main | Property Name | Description | | ------------- | ----------- | | Name | Name of the profile. | | Description | Optional description of the profile. | | Enabled | Whether the profile is active. | ### Email Settings | Property Name | Description | | ------------- | ----------- | | SMTP Profile | The [SMTP Profile](platform/gateway/web-interface/network/email-settings/email-settings.md) used to send notifications. | | On-Call Roster | The [roster](ignition-modules/alarm-notification/on-call-rosters/on-call-rosters.md) of users who will receive the notification. | ### Alarm Criteria | Property Name | Description | | ------------- | ----------- | | Minimum Priority | The lowest priority that will trigger this notification. Options are Diagnostic, Low, Medium, High, or Critical. | | Maximum Priority | The highest priority that will trigger this notification. Options are Diagnostic, Low, Medium, High, or Critical. | ### Consolidation | Property Name | Description | | ------------- | ----------- | | Consolidation Enabled | When checked, enables consolidation to combine multiple alarms into single notifications. | | Delay | The time, in seconds, to wait after an alarm is received to wait for another alarm before sending a message. | | Frequency | The time, in seconds, to wait after a notification is sent before sending another notification. | ### Advanced | Property Name | Description | | ------------- | ----------- | | From Address | Optional email address to appear in the "From" field. If left blank, the SMTP username is used. |
