title: "Remote Gateway Notification"
# Remote Gateway Notification
The Remote Gateway Notification profile allows one Gateway to send alarm notifications using a notification profile hosted on a different Gateway in the same Gateway Network. This lets you centralize email, SMS, and voice delivery infrastructure while distributing alarm generation across remote sites.
This is especially useful when remote Gateways lack direct access to email servers or telephony hardware. The remote Gateway triggers the alarm; the central Gateway handles the delivery.
:::info
The **Alarm Notification module** must be installed and licensed on all participating Gateways. However, notification-specific modules (like SMS or Voice) are only required on the Gateway that executes the notification.
:::info
Both Gateways must be connected via the Gateway Network.
## Create a Remote Gateway Notification Profile
Follow these steps to create a Remote Gateway Notification Profile.
1. In the Gateway, go to **Platform** > **Alarming** > **Notification**.
2. Click **Create Profile +**.
3. Select **Remote Gateway Notification**, then click **Next**.
4. Enter the required values using the following example:
* **Name**: Remote
* **Gateway**: IP address or name of the remote Gateway.
* **Notification Profile**: Email 1
5. Click **Create Alarm Notification Profile**.
6. The profile will appear in the list and show a status of **Connected** or **Registered** once the connection is successful.
Once created, this profile can be used in any local pipeline or notification block.
## Remote Gateway Notification Profile Settings
### General
| Property Name | Description |
| Name | Name of the notification profile. |
| Description | Optional description of the profile. |
| Enabled | Whether the profile is currently active. |
### Remote Gateway
| Gateway | IP address or hostname of the remote Gateway in the Gateway Network. |
| Notification Profile | Name of the alarm notification profile on the remote Gateway to be used for sending notifications. |
### Advanced
| Retry Delay | Time to wait (in milliseconds) before retrying a failed synchronization with the remote Gateway. Default: `10000`. |
| Max Queued Alarm Transitions | Maximum number of alarm transitions to hold in the queue while the remote Gateway is unavailable. Default: `10000`. |
## Assign a Remote Pipeline to an Alarm
After creating the profile, you can assign a remote pipeline to an alarm directly from the Tag Editor.
1. In the Designer, open the **Tag Browser** and double-click the tag you want to configure.
2. Scroll to the **Alarms** section and click the **Edit** icon for the alarm.
3. In the alarm editor, scroll to the **Notification Settings** section.
4. Under **Active Pipeline**, select a pipeline from the remote Gateway (e.g., Remote/Pipeline1).
5. Click **Commit** to save your changes.
Once saved, the tag will send alarm notifications using the remote Gateway’s pipeline.
:::info
Only the Gateway executing the notification must have the necessary notification modules installed (Email, SMS, or Voice).
You can also use the profile in a [Notification Block](ignition-modules/alarm-notification/alarm-notification-pipelines/alarm-notification-pipelines.md) within an alarm pipeline.
