--- title: "Installing or Upgrading a Module" --- # Installing or Upgrading a Module > >
## Module Configuration All module configuration is done from Gateway Webpage in the **Platform** > **System** > **Modules** section. The Modules page shows a list of the currently installed modules, their current version, and if they are running properly with a license. The top of the page shows a quick count of the running and licensed modules, so you can easily tell if anything is not working. It is then easy to scroll down through the list to see which modules are having issues. From here you can also add, remove, enable, and disable modules. Modules integrate their settings into the Gateway configuration tree, and therefore do not offer settings in this section. ![](install-upgrade-mod-imgs/2019-03-18_11-11-08.png) ## Downloading a Module Ignition comes with some default modules when installing the software. There may be a few modules you require that are not included when performing the initial installation, however. To find the module(s) you require, follow the instructions below. 1. Go to the [downloads page](https://inductiveautomation.com/downloads/) on the Inductive Automation website. ![](install-upgrade-mod-imgs/image2022-7-5_12-32-50.png) 2. Click on "Other Versions", located under the Ignition tablet and mobile device graphic. By default, this will take you to different installers and modules for the **latest** version of Ignition. ![](install-upgrade-mod-imgs/image2022-7-5_12-38-20.png) 3. Select which version of Ignition you are currently running. 4. Scroll down the page until you see which module you are looking for. Once you click on the target module, it will start downloading the .modl file. ## Install or Update a Module The following procedure assumes you have a .modl already downloaded in preparation for installing or upgrading a module, including for third party modules. :::note Installing a module will require connected Vision Clients and Designers to restart. Perspective Sessions will not require a restart. Production systems using either Clients or Designers should wait for downtime before installing a module. ::: 1. On the Gateway Webpage, select **Platform** > **System** > **Modules** to open the **Modules** page. 2. Click the **Install or Upgrade Module +**. 3. Click **Choose File**, select a .modl file that you have previously downloaded. ![](install-upgrade-mod-imgs/2019-03-18_11-27-04.png) 4. Click **Install**. When the page reloads you can now see the module you installed in the list of modules. ### Manual Module Installation Alternatively, you can add module files directly to your Gateway File System by following the steps below. This example will add the MongoDB Connector module. 1. Navigate to the `%IgnitionInstallationDirectory%/user-lib/modules` folder. 2. Add your .modl file to your modules folder. 3. After adding your new module, we will need to create an entry in our modules.json file to bring the MongoDB module into our Gateway. Go to `%IgnitionInstallationDirectory%/data` and open the **modules.json** file. 4. We will use the same format as the existing entries, and the **onStartup** and **certFingerprint** properties will use the same values. However, we will change the **module name** and **filename** (file path) properties to reflect using the MongoDB Connector module: * Module Name: `com.inductiveautomation.connectors.mongodb` * Filename: `C:\\Program Files\\Inductive Automation\\Ignition\\user-lib\\modules\\MongoDB Connector-module.modl` ![module.json MongoDB Entry](moduesJSONMongoDBEntry.png) 5. Once you have added your entry, save the modules.json file. 6. Restart your Gateway service. Your new module will now be ready to use. ## Uninstall a Module :::note Uninstalling a module will require connected Vision Clients and Designers to restart. Perspective Sessions will not require a restart. Production systems using either Clients or Designers should wait for downtime before uninstalling a module. ::: 1. On the Gateway Webpage, select **Platform** > **System** > **Modules** to open the **Modules** page. 2. Locate the module you want to uninstall. 3. To the right of module name, click the three dot menu and select **Uninstall**. ![](install-upgrade-mod-imgs/uninstall-module.png) 4. Click **Uninstall**. The module is no longer installed and is removed form the list. ![](install-upgrade-mod-imgs/confirm-uninstall.png) ## Disable a Module 1. On the Gateway Webpage, select **Platform** > **System** > **Modules** to open the **Modules** page. 2. Locate the module you want to disable. 3. To the right of module name, click the three dot menu and select **Disable**. A confirmation message appears. ![](install-upgrade-mod-imgs/disable-module.png) 4. Click **Disable**. The module status will change to Active Pending Restart until the Gateway has been restarted, and the [Gateway Restart Required banner](platform/gateway/web-interface/web-interface.md#banners) will appear at the bottom of the page. After the Gateway has been restarted, the module will still be listed but will not be functional. ## Enable a Module This option is only available for a currently disabled module. 1. On the Gateway Webpage, select **Platform** > **System** > **Modules** to open the **Modules** page. 2. Locate the module you want to enable. 3. To the right of module name, click the three dot menu and select **Enable**. A confirmation message appears. ![](install-upgrade-mod-imgs/2019-08-15_15-21-09.png) 4. Click **Enable**. The [Gateway Restart Required banner](platform/gateway/web-interface/web-interface.md#banners) will appear at the bottom of the page for you to easily restart your Gateway. After the Gateway has been restarted, the module will be enabled. ## Module Status The installed module list on the **Modules** page also provides some basic information about each module. The **Version**, **License**, and **Status** columns are all displayed in the list. [Module licensing](../../platform/licensing-and-activation/licensing-and-activation.md#licensing-modules) is performed centrally on the **Platform** > **System** > **Licensing** page, so the values on the Modules page are only for informational purposes. ### Module Shows as Faulted After Installation In some cases, a module may appear to install successfully, but its functionality does not become available. A common cause of this behavior is a version mismatch between the installed module and the Ignition platform. For a module to load correctly, the middle digit of the module version must match the middle digit of the Ignition platform version. If a version mismatch is detected, the module will display a Status of **Faulted** on the Modules page. ![](install-upgrade-mod-imgs/module-version-mismatch.png) To verify compatibility, navigate to **Diagnostics** > **Overview** and note the Ignition version currently running on your Gateway. ![](install-upgrade-mod-imgs/ignition-version.png) Because the WebDev module shown above has 1 as the middle digit and the Gateway has 3, there is a version mismatch and the module will remain in a faulted state. To resolve this, download the correct version of the module from the Inductive Automation [Downloads](https://inductionautomation.com/downloads/ignition) page. Use the Ignition Version dropdown or Version Archive tab to select the Ignition version that matches your Gateway. From the list of available modules, locate the compatible version and download it. ![](install-upgrade-mod-imgs/matching-versions.png) After installing the compatible version, the Gateway Restart Required banner will appear at the bottom of the Modules page. Click the **Restart Gateway** button to complete the installation. ![](install-upgrade-mod-imgs/restart-gw.png) Once the Gateway has been restarted, the module will show a Status of **Active**, and will become available for use. ![](install-upgrade-mod-imgs/module-version-active.png) ## Verify Trusted Modules Verify the authenticity of Ignition modules on the **Platform** > **System** > **Modules** page. Expand the three dot menu for your module and select **View Certificate** to see details about each certificate. A warning message will appear if the module certificate is expired, however this will not have any impact on security or module behavior. ![](install-upgrade-mod-imgs/2023-02-27_16-03-17.png) ## Quarantined Modules Near the bottom of the Modules page is the **Quarantined Modules** section. Modules can be quarantined for various reasons, such as a certificate being unsigned or needing review, or licensing issues. The Gateway will list the specific reason a module is quarantined, along with the module name and version. If a module has been quarantined, you can still trust it and add it to your Gateway. To do this, click on the three dots menu next to the quarantined module you want to use. You will be presented with an option to either resolve the quarantine reason or delete the module. ![Quarantined Module Three Dots Menu](quarantined-module-three-dots-menu.png) ## Third Party Modules Third Party modules are not produced by Inductive Automation. Ensure that you know who produced the code and perform due diligence as you would with any other software vendor in accordance with organizational policy. Strategic Partners, such as Cirrus Link, and Premier Technology Providers, such as 4IR and Sepasoft, are trusted parties by Inductive Automation. However, their modules or services are created by separate groups and may need to be vetted separately from the Ignition platform. The [Module Showcase](https://inductiveautomation.com/moduleshowcase/) hosts Ignition modules written by the community. Authors are required to request certificates from Inductive Automation (IA). IA will remove modules with known problems or risk, but hosting does not require a high level of vetting. Your account representative may be able to provide more information on known authors or organizations. The bundled version of Java in Ignition uses Java 17.0.13, which may impact third party module compatibility. Refer to third party module documentation for further communication about any end-user modifications that may be required.
