--- title: "system.vision.showPasswordInput" description: "Pops up a special input box that uses a password field, so the text isn't echoed back in clear-text to the user." --- # system.vision.showPasswordInput > Pops up a special input box that uses a password field, so the text isn't echoed back in clear-text to the user. :::info Backwards Compatibility This function replaces [system.gui.passwordBox](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-passwordBox.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Pops up a special input box that uses a password field, so the text isn't echoed back in clear-text to the user. Returns the text they entered, or None if they canceled the dialog box. :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.showPasswordInput(message, [title], [echoChar])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `message` | The message for the password prompt. Will accept HTML formatting. String| `title` | A title for the password prompt. [optional] String| `echoChar` | A custom echo character. Defaults to: `*` [optional] ### Returns **String** - The password that was entered, or None if the prompt was canceled. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example prompts a user for a password before opening the 'Admin' screen. password = system.vision.showPasswordInput("Please enter the password.") if password == "open sesame": system.vision.openWindow("Admin") ```
