--- title: "system.vision.showNumericKeypad" description: "Displays a modal on-screen numeric keypad, allowing for arbitrary numeric entry using the mouse, or a finger on a touchscreen monitor." --- # system.vision.showNumericKeypad > Displays a modal on-screen numeric keypad, allowing for arbitrary numeric entry using the mouse, or a finger on a touchscreen monitor. :::info Backwards Compatibility This function replaces [system.gui.showNumericKeypad](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-show-NumericKeypad.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Displays a modal on-screen numeric keypad, allowing for arbitrary numeric entry using the mouse, or a finger on a touch screen monitor. Returns the number that the user entered. :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.showNumericKeypad(initialValue, [fontSize], [usePasswordMode])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Number| `initialValue` | The value to start the on-screen keypad with. Integer| `fontSize` | The font size to display in the keypad. [optional] Boolean| `usePasswordMode` | If True, display a `*` for each digit. [optional] ### Returns **Number** - The value that was entered in the keypad. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This function is a holdover for backwards compatibility. Input components now know when the Client is in Touch Screen mode and respond accordingly. # This script would go in the MouseClicked or MousePressed action of a Text field or Numeric Text field. # For Integer Numeric Text field: if system.vision.isTouchscreenMode(): event.source.intValue = system.vision.showNumericKeypad(event.source.intValue) # For Double Numeric Text field: if system.vision.isTouchscreenMode(): event.source.doubleValue = system.vision.showNumericKeypad(event.source.doubleValue) # For Text field: # Notice the str() and int() functions used to convert the text to a number and # vice versa. # str() and int() are built-in Jython functions if system.vision.isTouchscreenMode(): event.source.text = str(system.vision.showNumericKeypad(int(event.source.text))) ```
