--- title: "system.vision.showError" description: "Displays an error-style message box to the user." --- # system.vision.showError > Displays an error-style message box to the user. :::info Backwards Compatibility This function replaces [system.gui.errorBox](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-errorBox.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.showError(message, [title])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `message` | The message to display in an error box. Will accept HTML formatting. String| `title` | The title for the error box. [optional] ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1 - Using Error Box" # Turn on compressor #12, but only if the user has the right credentials. if 'Supervisor' in system.vision.getRoles(): updateQuery = "UPDATE CompressorControl SET running=1 WHERE compNum = 12" system.db.runUpdateQuery(updateQuery) else: errorMessage = "Unable to turn on Compressor 12." errorMessage += " You don't have proper security privileges." system.vision.showError(errorMessage) ```
