--- title: "system.vision.showDiagnostics" description: "Opens the client runtime diagnostics window, which provides information regarding performance, logging, active threads, connection status, and the console." --- # system.vision.showDiagnostics > Opens the client runtime diagnostics window, which provides information regarding performance, logging, active threads, connection status, and the console. :::info Backwards Compatibility This function replaces [system.gui.openDiagnostics](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-openDiagnostics.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Opens the Client runtime Diagnostics window, which provides information regarding performance, logging, active threads, connection status, and the console. This provides an opportunity to open the Diagnostics window in situations where the menu bar in the client is hidden, and the keyboard shortcut (**Ctrl** + **Shift** + **F7**) can not be used. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.showDiagnostics()` ### Parameters Nothing ### Returns Nothing ### Scope Vision Client ## Code Example ```python title="Opening Diagnostics Window" # Opens the diagnostics window in a running client system.vision.showDiagnostics() ```
