--- title: "system.vision.showConfirm" description: "Displays a confirmation dialog box to the user with Yes and No options, and a custom message." --- # system.vision.showConfirm > Displays a confirmation dialog box to the user with Yes and No options, and a custom message. :::info Backwards Compatibility This function replaces [system.gui.confirm](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-confirm.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Displays a confirmation dialog box to the user with **Yes** and **No** options, and a custom message. :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.showConfirm(message, [title], [allowCancel])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `message` | The message to show in the confirmation dialog. String| `title` | The title for the confirmation dialog. [optional] Boolean| `allowCancel` | Show a cancel button in the dialog. [optional] ### Returns **Boolean** - True if the user selected **Yes**; false if the user selected **No**. None if the user selected **Cancel**. ### Scope Vision Client ## Code Examples ```python title="Example #1" # By using the confirm function in an if statement, we can let the user confirm an action. # In this case, we shut down the plant if the user confirms it; otherwise, we don't do anything. if system.vision.showConfirm("Are you sure you want to shutdown the plant?", "Really Shutdown?"): system.db.runPrepUpdate( "UPDATE ControlTable SET Shutdown = ?", [1] ) ```
