--- title: "system.vision.showColorInput" description: "Prompts the user to pick a color using the default color-chooser dialog box." --- # system.vision.showColorInput > Prompts the user to pick a color using the default color-chooser dialog box. :::info Backwards Compatibility This function replaces [system.gui.chooseColor](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-chooseColor.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.showColorInput(initialColor, [dialogTitle])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Color| `initialColor` | A color to use as a starting point in the color choosing popup. String| `dialogTitle` | The title for the color choosing popup. Defaults to "Choose Color". [optional] ### Returns **Color** - The new color chosen by the user. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code would be placed in the actionPerformed event of a button # and would change the background color of the container the button was placed in. parent = event.source.parent newColor = system.vision.showColorInput(parent.background) parent.background = newColor ```
