--- title: "system.vision.setScreenIndex" description: "Moves an open client to a specific monitor." --- # system.vision.setScreenIndex > Moves an open client to a specific monitor. :::info Backwards Compatibility This function replaces [system.gui.setScreenIndex](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-setScreenIndex.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Moves an open client to a specific monitor. Use with [system.vision.getScreens()](appendix\scripting-functions\system-vision\system-vision-getScreens.md) to identify monitors before moving. :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.setScreenIndex(index)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Integer | `index` | The new monitor index for this client to move to. 0 based. ### Returns Nothing ### Scope Vision Client ## Code Example ```python title="Setting a Screen's Index" # This example could be used on a startup script to move the client to a 2nd monitor. system.vision.setScreenIndex(1) ```
