--- title: "system.vision.setOverlaysEnabled" description: "Enables or disables the component quality overlay system." --- # system.vision.setOverlaysEnabled > Enables or disables the component quality overlay system. :::info Backwards Compatibility This function replaces [system.tag.setOverlaysEnabled](versioned_docs/version-8.1/appendix/scripting-functions/system-tag/system-tag-setOverlaysEnabled.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.setOverlaysEnabled(enabled)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Boolean | `enabled` | True to turn on tag overlays; false to turn them off. ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example will turn tag overlays on. system.vision.setOverlaysEnabled(True) ```
