--- title: "system.vision.setLocale" description: "Sets the user's current Locale." --- # system.vision.setLocale > Sets the user's current Locale. :::info Backwards Compatibility This function replaces [system.util.setLocale](versioned_docs/version-8.1/appendix/scripting-functions/system-util/system-util-setLocale.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Sets the user's current Locale. Any valid Java locale code (case-insensitive) can be used as a parameter, including ones that have not yet been added to the Translation Manager. An invalid locale code will cause an Illegal Argument Exception. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.setLocale(locale)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Object | `locale` | A locale code, such as "en_US" for US English, or a java.util.Locale object. ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This script will set the client locale to Arabic. system.vision.setLocale('ar') ```
