--- title: "system.vision.setConnectionMode" description: "Sets the connection mode for the Client session." --- # system.vision.setConnectionMode > Sets the connection mode for the Client session. :::info Backwards Compatibility This function replaces [system.util.setConnectionMode](versioned_docs/version-8.1/appendix/scripting-functions/system-util/system-util-setConnectionMode.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Sets the connection mode for the Client session. Normally a Client runs in mode 3, which is read-write. You may wish to change this to mode 2, which is read-only, which will only allow reading and subscribing to tags, and running SELECT queries. Tag writes and INSERT/UPDATE/DELETE queries will not function. You can also set the connection mode to mode 1, which is disconnected, all tag and query features will not work. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.setConnectionMode(mode)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Integer | `mode` | The new connection mode. 1 = Disconnected, 2 = Read-only, 3 = Read/Write. ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example, which could go in a project's startup script, would check the current username # and set the connection mode to read-only if it is the "guest" user. username = system.vision.getUsername() if "guest" == username.lower(): # Set "guest" user to read-only mode system.vision.setConnectionMode(2) else: system.vision.setConnectionMode(3) ```
