--- title: "system.vision.setConnectTimeout" description: "Sets the connect timeout for Client-to-Gateway communication." --- # system.vision.setConnectTimeout > Sets the connect timeout for Client-to-Gateway communication. :::info Backwards Compatibility This function replaces [system.util.setConnectTimeout](versioned_docs/version-8.1/appendix/scripting-functions/system-util/system-util-setConnectTimeout.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Sets the connect timeout for Client-to-Gateway communication. Specified in milliseconds. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.setConnectTimeout(connectTimeout)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Integer| `connectTimeout` | The new connect timeout, specified in milliseconds. ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code would set the current connect timeout to 30 seconds system.vision.setConnectTimeout(30000) ```
