--- title: "system.vision.saveFile" description: "Prompts the user to save a new file named filename." --- # system.vision.saveFile > Prompts the user to save a new file named filename. :::info Backwards Compatibility This function replaces [system.file.saveFile](versioned_docs/version-8.1/appendix/scripting-functions/system-file/system-file-saveFile.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Prompts the user to save a new file named filename. The optional extension and typeDesc arguments will be used for a file type filter, if any. If the user accepts the save, the path to that file will be returned. If the user cancels the save, None will be returned. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax #1 `system.vision.saveFile(filename)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `filename` | A file name to suggest to the user. ### Returns **String** - The path to the file that the user decided to save to, or None if they canceled. ### Scope Vision Client ## Syntax #2 `system.vision.saveFile(filename, [extension], [typeDesc])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `filename` | A file name to suggest to the user. String| `extension` | The appropriate file extension, like "jpeg", for the file. [optional] String| `typeDesc` | A description of the extension, like "JPEG Image". [optional] ### Returns **String** - The path to the file that the user decided to save to, or None if they canceled. ### Scope Vision Client ## Code Examples ```python title="Example #1 - Saving a File (Text Area)" # This code would prompt the user to save the text in a text area to a file. path = system.vision.saveFile("myfile.txt") if path is not None: system.file.writeFile(path, event.source.parent.getComponent("Text Area").text) ``` ```python title="Example #2 - Saving a File (Script Console)" # This code prompts the user to save direct text in the system.file.writeFile()'s data parameter to a file. path = system.vision.saveFile("myfile.txt") if path is not None: system.file.writeFile(path, "Hello World") ```
