--- title: "system.vision.printToImage" description: "This function prints the given component (such as a graph, container, entire window, etc) to an image file, and saves the file where ever the operating system deems appropriate." --- # system.vision.printToImage > This function prints the given component (such as a graph, container, entire window, etc) to an image file, and saves the file where ever the operating system deems appropriate. :::info Backwards Compatibility This function replaces [system.print.printToImage](versioned_docs/version-8.1/appendix/scripting-functions/system-print/system-print-printToImage.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description This function prints the given component (such as a graph, container, entire window, etc) to an image file, and saves the file where ever the operating system deems appropriate. A filename and path may be provided to determine the name and location of the saved file. While not required, it is highly recommended to pass in a filename and path. The script may fail if the function attempts to save to a directory that the client does not have access rights to. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.printToImage(component [, filename])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Component| `component` | The component to render. String| `filename` | A filename to save the image as. [optional] ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code would go on a button and save an image of the container that it is in. system.vision.printToImage(event.source.parent, "C:\\temp\\Screen.jpg") ``` ```python title="Example #2 - User Selected Location" # Again, this example would save an image of the container, but prompts the user for a # location and filename with system.vision.saveFile() # Ask the user for a location. Uses a default filename of "image.png" path = system.vision.saveFile("image.png") # If the path is not None... if path != None: #Save the file system.vision.printToImage(event.source.parent, path) ```
