--- title: "system.vision.openURL" description: "Opens the given URL or URI scheme outside of the currently running Client in whatever application the host operating system deems appropriate." --- # system.vision.openURL > Opens the given URL or URI scheme outside of the currently running Client in whatever application the host operating system deems appropriate. :::info Backwards Compatibility This function replaces [system.net.openURL](versioned_docs/version-8.1/appendix/scripting-functions/system-net/system-net-openURL.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Opens the given URL or URI scheme outside of the currently running Client in the application the host operating system deems appropriate. For example, the URL `"http://www.google.com"` will open in the default web browser, whereas `"file://C:\\Report.pdf"` will open in Adobe Acrobat. The Windows network-share style path like `"\\\\Fileserver\\resources\\machine_manual.pdf"` will work in Windows as well. :::caution Be careful not to use this function in a full-screen client, as launching an external program will break your full-screen exclusive mode. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.openURL(url)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `url` | The URL to open in a web browser or other appropriate application. ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code will open a web page system.vision.openURL("http://www.google.com") ``` ```python title="Example #2" # This code will open a PDF document located at C: on the client computer # Note the double backslashes are needed because backslash is the escape character # for Python system.vision.openURL("file://C:\\myPDF.pdf") ``` ```python title="Example #3" # This code would open a PDF document from a Windows-based file server # Note the double backslashes are needed because backslash is the escape character # for Python system.vision.openURL("\\\\MyServer\\MyDocs\\document.pdf") ```
