--- title: "system.vision.logout" description: "Logs out of the client for the current user and brings the client to the login screen." --- # system.vision.logout > Logs out of the client for the current user and brings the client to the login screen. :::info Backwards Compatibility This function replaces [system.security.logout](versioned_docs/version-8.1/appendix/scripting-functions/system-security/system-security-logout.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Logs out of the Client for the current user and brings the Client to the login screen. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.logout()` ### Parameters Nothing ### Returns Nothing ### Scope All ## Code Example ```python title="Code Snippet" # This would run in a timer script to log the user out after 30 seconds of inactivity. if system.vision.getInactivitySeconds() > 30: system.vision.logout() ```
