--- title: "system.vision.isScreenLocked" description: "Returns whether or not the screen is currently locked." --- # system.vision.isScreenLocked > Returns whether or not the screen is currently locked. :::info Backwards Compatibility This function replaces [system.security.isScreenLocked](versioned_docs/version-8.1/appendix/scripting-functions/system-security/system-security-isScreenLocked.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.isScreenLocked()` ### Parameters Nothing ### Returns **Boolean** - A flag indicating whether or not the screen is currently locked. ### Scope Vision Client ## Code Example ```python title="Code Snippet" # This would run in a timer script to lock the screen after 15 seconds of inactivity, # and then log the user out after 30 seconds of inactivity. if system.vision.getInactivitySeconds() > 15 and not system.vision.isScreenLocked(): system.vision.lockScreen() elif system.vision.getInactivitySeconds() > 30: system.vision.logout() ```
