--- title: "system.vision.isOverlaysEnabled" description: "Returns whether or not the current client's quality overlay system is currently enabled." --- # system.vision.isOverlaysEnabled > Returns whether or not the current client's quality overlay system is currently enabled. :::info Backwards Compatibility This function replaces [system.tag.isOverlaysEnabled](versioned_docs/version-8.1/appendix/scripting-functions/system-tag/system-tag-isOverlaysEnabled.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.isOverlaysEnabled()` ### Parameters Nothing ### Returns **Boolean** - True if overlays are currently enabled. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code will return whether or not overlays are currently enabled. print system.vision.isOverlaysEnabled() ```
