--- title: "system.vision.getUsername" description: "Returns the currently logged-in username." --- # system.vision.getUsername > Returns the currently logged-in username. :::info Backwards Compatibility This function replaces [system.security.getUsername](versioned_docs/version-8.1/appendix/scripting-functions/system-security/system-security-getUsername.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Returns the current username logged in. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.getUsername()` ### Parameters Nothing ### Returns **String** - The current username. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code would run on a startup script based on who was logging in. name = system.vision.getUsername() if name == 'Bob': system.vision.openWindow("BobsHomepage") else: system.vision.openWindow("NormalHomepage") ```
