--- title: "system.vision.getScreenIndex" description: "Returns an integer value representing the current screen index based on the screen from which this function was called." --- # system.vision.getScreenIndex > Returns an integer value representing the current screen index based on the screen from which this function was called. :::info Backwards Compatibility This function replaces [system.gui.getScreenIndex](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-getScreenIndex.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.getScreenIndex()` ### Parameters Nothing ### Returns **Integer** - The screen from which the function was called. ### Scope Vision Client ## Code Examples ```python title="Example #1" # Prints an integer representing the screen from which the function was called. print system.vision.getScreenIndex() ```
