--- title: "system.vision.getReadTimeout" description: "Returns the read timeout in milliseconds for all client-to-gateway communication." --- # system.vision.getReadTimeout > Returns the read timeout in milliseconds for all client-to-gateway communication. :::info Backwards Compatibility This function replaces [system.util.getReadTimeout](versioned_docs/version-8.1/appendix/scripting-functions/system-util/system-util-getReadTimeout.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Returns the read timeout in milliseconds for all client-to-gateway communication. This is the maximum amount of time allowed for a communication operation to complete. The default is 60,000ms (1 minute). ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.getReadTimeout()` ### Parameters Nothing ### Returns **Integer** - The current read timeout, in milliseconds. Default is 60,000 (one minute) ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code will find the current read timeout and write it to a numeric text field on the same page. event.source.parent.getComponent('Numeric Text Field').intValue = system.vision.getReadTimeout() ```
