--- title: "system.vision.getOpenedWindows" description: "Finds all of the currently open windows and returns a tuple of references to them." --- # system.vision.getOpenedWindows > Finds all of the currently open windows and returns a tuple of references to them. :::info Backwards Compatibility This function replaces [system.gui.getOpenedWindows](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-getOpenWindows.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Syntax `system.vision.getOpenedWindows()` ### Parameters Nothing ### Returns **Tuple** - A tuple of the opened windows, not their names, but the actual [window](appendix\components\vision-components\vision-window-object\vision-window-object.md) objects themselves. Printing the return value will display results in the Vision Client console if not writing to a component property. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example prints out the path of each currently opened window to the console. windows = system.vision.getOpenedWindows() print 'There are %d windows open' % len(windows) for window in windows: print window.getPath() ```
