--- title: "system.vision.getInactivitySeconds" description: "Returns the number of seconds since any keyboard or mouse activity." --- # system.vision.getInactivitySeconds > Returns the number of seconds since any keyboard or mouse activity. :::info Backwards Compatibility This function replaces [system.util.getInactivitySeconds](versioned_docs/version-8.1/appendix/scripting-functions/system-util/system-util-getInactivitySeconds.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description :::note This function will always return zero in the Designer. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.getInactivitySeconds()` ### Parameters Nothing ### Returns **Integer** - The number of seconds the mouse and keyboard have been inactive for this client. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code could run in a global timer script. # After a 5-minute timeout, navigate back to the home screen if system.vision.getInactivitySeconds()>300 and system.vision.getCurrentWindow()!="Home": system.vision.swapTo("Home") ```
