--- title: "system.vision.getExternalIpAddress" description: "Returns the Client's IP address, as it is detected by the Gateway." --- # system.vision.getExternalIpAddress > Returns the Client's IP address, as it is detected by the Gateway. :::info Backwards Compatibility This function replaces [system.net.getExternalIpAddress](versioned_docs/version-8.1/appendix/scripting-functions/system-net/system-net-getExternalIpAddress.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Returns the Client's IP address, as it is detected by the Gateway. This means that this call will communicate with the Gateway, and the Gateway will tell the Client what IP address its incoming traffic is coming from. If you have a client behind a Network Address Translation (NAT) router, then this address will be the Wide Area Network (WAN) address of the router instead of the Local Area Network (LAN) address of the Client, which is what you'd get with [system.net.getIpAddress](appendix/scripting-functions/system-net/system-net-getIpAddress.md). ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.getExternalIpAddress()` ### Parameters Nothing ### Returns **String** - A text representation of the client's IP address, as detected by the Gateway ### Scope Vision Client ## Code Examples ```python title="Code Snippet" # Put this script on a navigation button to restrict users from opening a specific page. ip = system.vision.getExternalIpAddress() # check if this matches the CEO's IP address if ip == "66.102.7.104": system.vision.swapTo("CEO Dashboard") else: system.vision.swapTo("Manager Dashboard") ```
