--- title: "system.vision.getEdition" description: "Returns the edition of the Vision Client." --- # system.vision.getEdition > Returns the edition of the Vision Client. :::info Backwards Compatibility This function replaces [system.util.getEdition](versioned_docs/version-8.1/appendix/scripting-functions/system-util/system-util-getEdition.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Returns the edition of the Vision Client: * Standard * Limited * Panel ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.getEdition()` ### Parameters Nothing ### Returns **String** - The edition of the Vision module that is running the Client. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code will write the Vision module edition to a text field on the same page. event.source.parent.getComponent('Text Field').text = system.vision.getEdition() ```
