--- title: "system.vision.getDesktopHandles" description: "Gets a list of all secondary handles of the open desktops associated with the current client." --- # system.vision.getDesktopHandles > Gets a list of all secondary handles of the open desktops associated with the current client. :::info Backwards Compatibility This function replaces [system.gui.getDesktopHandles](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-getDesktopHandles.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Gets a list of all **secondary** handles of the open desktops associated with the current client. In this case, **secondary** means any desktop frame opened by the original client frame. For example, if the original client opened two new frames ('left client' and 'right client'), then this function would return ['left client', 'right client']. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details. :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.getDesktopHandles()` ### Parameters Nothing ### Returns **List[Any]** - A Python list of unicode strings, representing the handle of all secondary desktop frames. ### Scope Vision Client ## Code Examples ```python title="Example #1 - Getting Desktop Handles" # The following example list all handles (except the main client) # in the client console (Help -> Diagnostics -> Console) print system.vision.getDesktopHandles() ``` ```python title="Example #2 - Putting Desktop Handles in a Table" # Create the header and fetch handle names header = ["Desktop Names"] handleList = system.vision.getDesktopHandles() # change the handle name list into a column handleColumn = [[name] for name in handleList] # display the handle list in a table component event.source.parent.getComponent('Handles Table').data = system.dataset.toDataset(header, handleColumn) ```
