--- title: "system.vision.getConnectTimeout" description: "Returns the connect timeout in milliseconds for all Client-to-Gateway communication." --- # system.vision.getConnectTimeout > Returns the connect timeout in milliseconds for all Client-to-Gateway communication. :::info Backwards Compatibility This function replaces [system.util.getConnectTimeout](versioned_docs/version-8.1/appendix/scripting-functions/system-util/system-util-getConnectTimeout.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Returns the connect timeout in milliseconds for all Client-to-Gateway communication. This is the maximum amount of time that communication operations to the Gateway will be given to connect. The default is 10,000ms (10 seconds). ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.getConnectTimeout()` ### Parameters Nothing ### Returns **Integer** - The current connect timeout, in milliseconds. Default is 10,000 (ten seconds) ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code would print out the current connect timeout print system.vision.getConnectTimeout() ```
