--- title: "system.vision.exportHTML" description: "Exports the contents of a dataset to an HTML page. Prompts the user to save the file to disk." --- # system.vision.exportHTML > Exports the contents of a dataset to an HTML page. Prompts the user to save the file to disk. :::info Backwards Compatibility This function replaces [system.dataset.exportHTML](versioned_docs/version-8.1/appendix/scripting-functions/system-dataset/system-dataset-exportHTML.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Exports the contents of a [dataset](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md) to an HTML page. Prompts the user to save the file to disk. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.exportHTML(filename, showHeaders, dataset, title)` ### Parameters Type | Parameter | Description ------- | ------- | ------- String | `filename` | A suggested filename to save as. Boolean | `showHeaders` | If true, the HTML table will include a header row. Dataset / PyDataset | `dataset` | The dataset to export. String | `title` | The title for the HTML page. ## Returns **String** - The path to the saved file, or None if the action was canceled by the user. ### Scope Vision Client ## Code Examples ```python title="Code Snippet - Export then Open" # This snippet prompts the user to save the data currently displayed in a Vision Table component to an HTML # file, and opens the file in the default web browser after a successful save. table = event.source.parent.getComponent("Table") filePath = system.vision.exportHTML("data.html", 1, table.data, "Production Report") if filePath != None: system.vision.openURL("file://"+filePath) ```
