--- title: "system.vision.exportExcel" description: "Exports the contents of a dataset as an Excel spreadsheet, prompting the user to save the file to disk. " --- # system.vision.exportExcel > Exports the contents of a dataset as an Excel spreadsheet, prompting the user to save the file to disk. :::info Backwards Compatibility This function replaces [system.dataset.exportExcel](versioned_docs/version-8.1/appendix/scripting-functions/system-dataset/system-dataset-exportExcel.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Exports the contents of a [dataset](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md) as an Excel spreadsheet, prompting the user to save the file to disk. To write silently to a file, you cannot use the vision.export* functions. Instead, use the [system.dataset.toExcel](appendix\scripting-functions\system-dataset\system-dataset-toExcel.md) function. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.exportExcel(filename, showHeaders, dataset, [nullsEmpty])` ### Parameters Type | Parameter | Description ------- | ------- | ------- String | `filename` | A suggested filename to save as. Boolean | `showHeaders` | If true, the spreadsheet will include a header row. Dataset \ List[Dataset] | `dataset` | Either a single dataset, or a list of datasets. When passing a list, each element represents a single sheet in the resulting workbook. Boolean | `nullsEmpty` | If True, the spreadsheet will leave cells with NULL values empty, instead of allowing Excel to provide a default value like 0. Defaults to False. [optional] ### Returns **String** - The path to the saved file, or None if the action was canceled by the user. ### Scope Vision Client ## Code Examples ```python title="Code Snippet" # This snippet prompts the user to save the data currently displayed in a Table component # to an Excel-compatible spreadsheet file. It opens the file after a successful save. table = event.source.parent.getComponent("Table") filePath = system.vision.exportExcel("data.xlsx", 1, table.data) if filePath != None: system.net.openURL("file://"+filePath) ```
