--- title: "system.vision.color" description: "Creates a new color object, either by parsing a string or by having the RGB[A] channels specified explicitly." --- # system.vision.color > Creates a new color object, either by parsing a string or by having the RGB[A] channels specified explicitly. :::info Backwards Compatibility This function replaces [system.gui.color](versioned_docs/version-8.1/appendix/scripting-functions/system-gui/system-gui-color.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Creates a new color object, either by parsing a string or by having the RGB[A] channels specified explicitly. See [toColor](appendix\expression-functions\type-casting\toColor.md) to see a list of available color names. :::tip This function accepts keyword arguments. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax (String) `system.vision.color(color)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `color` | A string that will be coerced into a color. Can accept many formats, such as "red" or "#FF0000" or "255,0,0". ### Returns **Color** - The newly created color. ### Scope Vision Client ## Syntax (int) `system.vision.color(red, green, blue, [alpha])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Integer| `red` | The red component of the color, an integer 0-255. Integer| `green` | The green component of the color, an integer 0-255. Integer| `blue` | The blue component of the color, an integer 0-255. Integer| `alpha` | The alpha component of the color, an integer 0-255. [optional] ### Returns **Color** - The newly created color. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example changes the background color of a component to red. myComponent = event.source myComponent.background = system.vision.color(255,0,0) ```
