--- title: "system.vision.closeParentWindow" description: "Closes the parent window given a component event object." --- # system.vision.closeParentWindow > Closes the parent window given a component event object. :::info Backwards Compatibility This function replaces [system.nav.closeParentWindow](versioned_docs/version-8.1/appendix/scripting-functions/system-nav/system-nav-closeParentWindow.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.closeParentWindow(event)` ### Parameters Type | Parameter | Description ------- | ------- | ------ EventObject | `event` | A component event object. The enclosing window for the component will be closed. Refer to [EventObject](https://docs.oracle.com/en/java/javase/11/docs/api/java.base/java/util/EventObject.html). ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code would be placed in the actionPerformed event of a button, # and would close the window that contained the button. system.vision.closeParentWindow(event) ```
