--- title: "system.vision.centerWindow" description: "Given a window path, or a reference to a window itself, it will center the window." --- # system.vision.centerWindow > Given a window path, or a reference to a window itself, it will center the window. :::info Backwards Compatibility This function replaces [system.nav.centerWindow](versioned_docs/version-8.1/appendix/scripting-functions/system-nav/system-nav-centerWindow.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Given a window path, or a reference to a window itself, it will center the window. The window should be floating an non-maximized. If the window can't be found, this function will do nothing. :::note This function is available on secondary desktops via the [system.vision.desktop](system-vision-desktop.md) function. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details on secondary desktops. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax #1 (String param) `system.vision.centerWindow(windowPath)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `windowPath` | The path of the window to center. ### Returns Nothing ### Scope Vision Client ## Syntax #2 (FPMIWindow param) `system.vision.centerWindow(window)` ### Parameters Type | Parameter | Description ------- | ------- | ------ FPMIWindow | `window` | A reference to the window to center. ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example centers the window named 'Overview'. system.vision.centerWindow('Overview') ```
