--- title: "system.vision.beep" description: "Tells the computer where the script is running to make a \"beep\" sound." --- # system.vision.beep > Tells the computer where the script is running to make a "beep" sound. :::info Backwards Compatibility This function replaces [system.util.beep](versioned_docs/version-8.1/appendix/scripting-functions/system-util/system-util-beep.md). Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. ::: This function is used in **Python Scripting**. ## Description Tells the computer where the script is running to make a "beep" sound. The computer must have a way of producing sound. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.vision.beep()` ### Parameters Nothing ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This will simply cause the system where the script is being executed to emit a beep sound. # That system must have a way to produce sound, such as speakers or headphones. system.vision.beep() ```
