Version: 8.3
system.util.translate
This function allows you to retrieve the global translation of a term from the translation database using the current locale.
tip
system.util.translate(term, [locale], [strict])
StringtermThe term to look up.
StringlocaleWhich locale to translate against, such as "it" or "en-IE". Accepts both the BCP-47 language tag (recommended) and the legacy underscore formats. Make sure to use locale codes for either format, and not language names, such as "Italian". Useful when there are multiple locales defined for a single term. If omitted, the function attempts to use the current locale (as defined by the client, session, or Designer). [optional]
BooleanstrictIf false, the function will return the passed term (param 1) if it could not find a defined translation for the locale: meaning, if you pass a term that hasn't been configured, the function will just send the term back to you. If true, then the function will return a None when it fails to find a defined translation. Default is false. [optional]
String - The translated term.
Example #1
# This script will take a term written into a Text Field component, translate it using the translation database,
# and then write it back to the same Text Field.
# it uses the current locale since none is specified.
text = event.source.parent.getComponent('Text Field').text
translation = system.util.translate(text)
event.source.parent.getComponent('Text Field').text = translation
Example #2
# This code block demonstrates how to use the locale parameter.
# Use the currently detected locale.
system.util.translate("Hello")
# Translate to Italian.
system.util.translate("Hello", "it")
# Translate to a regional variant - Irish English in this case.
system.util.translate("Hello", "en-ie")
