Version: 8.3
system.util.getVersion
Returns the Ignition version number that is currently being run.
note
If the version is from a nightly build or developer version that is not yet released, the version number will come back as "Dev Version", for example:
system.util.getVersion()
Nothing
Version - The currently running Ignition version number, as a Version object.
The following table documents available attributes on the object.
Method and/or AttributeDescriptionReturn Type
.majorReturns only the major version number.
8.0.2 returns 8
Integer
.minorReturns only the minor version number.
8.0.2 returns 0
Integer
isFutureVersion()Takes in a string version number and returns whether the current version is greater than the given version (true or false). Note: this does account for Snapshot, RC or Beta versions.
Version format expected: "X.X.X" ie "8.0.7" See example below.
Boolean
Example #1
# This code displays the name of the currently running Ignition version number.
system.vision.showMessage("You are running project: %s" % system.util.getVersion())
Example #2
# This code displays whether a given version is older than the current version.
currentVersion = system.util.getVersion()
testVersion = "8.0.7"
isFuture = currentVersion.isFutureVersion(testVersion)
print "Your version (%s) is older than %s: %s" %(currentVersion, testVersion, isFuture)
