system.user.removeHoliday
Descriptionβ
Allows a holiday to be deleted.
Permission Type: User Management
Syntaxβ
system.user.removeHoliday(holidayName)
Parametersβ
| String | holidayName | The name of the holiday to delete. Case-sensitive. |
Returnsβ
UIResponse - A list of UIResponse objects with lists of warnings, errors, and info about the success or failure of the deletion. The contents of the lists are accessible from the getter methods.
getWarns()- Returns a list of warning messages that were encountered during the deletion.getErrors()- Returns a list of error messages that were encountered during the deletion.getInfos()- Returns a list of "info" messages that were encountered during the deletion.
These messages represent normal logging events that occurred during the deletion, and can be useful when trying to visualize the events that lead up to a failure.
Scopeβ
Code Examplesβ
Example #1
def printResponse(responseList):
if len(responseList) > 0:
for response in responseList:
print "", response
else:
print " None"
holidayName = "Labor Day"
response = system.user.removeHoliday(holidayName)
warnings = response.getWarns()
print "Warnings are:"
printResponse(warnings)
errors = response.getErrors()
print "Errors are:"
printResponse(errors)
infos = response.getInfos()
print "Infos are:"
printResponse(infos)
"""The example above outputs the following:
Warnings are:
None
Errors are:
None
Infos are:
Holiday "Labor Day" deleted.
