Version: 8.3
system.user.getSchedule
Returns a specific schedule.
system.user.getSchedule(scheduleName)
StringscheduleNameThe name of the schedule to return. Case-sensitive
ScheduleModel - The schedule, which can be a BasicScheduleModel object, CompositeScheduleModel object, or another type registered by a module. If a schedule was not found, the function will return None if called from a Vision Client or the Designer. if called in from a Perspective Session or anywhere else in the Gateway scope, will throw an IllegalArgumentException.
Example #1
# This example will get a schedule and print info about it.
# This function handles recursive printing of the different schedule types. Modules can register more types than listed here.
def printScheduleInfo(aSchedule):
if aSchedule.getType() == "basic schedule":
print "Basic schedule type: ",aSchedule.getName(), aSchedule.getDescription(), aSchedule.isAllDays(), aSchedule.isObserveHolidays()
elif aSchedule.getType() == "composite schedule":
compositePieces = aSchedule.getModels()
print "Composite schedule type:",aSchedule.getName(), aSchedule.getDescription(), " which is made up of..."
for piece in compositePieces:
printScheduleInfo(piece)
else:
print "Other schedule type: ", aSchedule.getName(), aSchedule.getDescription(), aSchedule.getType(), aSchedule.isObserveHolidays()
# The main function.
scheduleName = "MySchedule"
schedule = system.user.getSchedule(scheduleName)
if schedule == None:
print "Schedule", scheduleName, "was not found"
else:
printScheduleInfo(schedule)
"""The example above outputs the following:
Basic schedule type: MySchedule A description False True"""
