--- title: "system.user.editUser" description: "Alters a specific user in a user source, replacing the previous data with the new data passed in." --- # system.user.editUser > Alters a specific user in a user source, replacing the previous data with the new data passed in. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.editUser(userSource, user)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `userSource` | The user source in which the user is found. Blank will use the default user source. User| `user` | The user to update, as a [User](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/user/User.html) object. Refer also to the [PyUser](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/user/PyUser.html) class. :::note Setting the User's Language The user's `Language` attribute holds a locale identifier, such as `es` or `es-ES`. This attribute accepts both the BCP-47 language tag (recommended) and the legacy underscore formats. Make sure to use locale codes for either format, and not language names, such as `"Spanish"`. See the [Locale Formats and Language Tags](../../../platform/localization-and-languages/locale-formats/locale-formats.md) page for details on each format. ::: ### Returns A [UIResponse](https://sdk.inductiveautomation.com/javadoc/ignition83/latest/com/inductiveautomation/ignition/common/messages/UIResponse.html) object with lists of warnings, errors, and information returned after the edit attempt. The contents of the lists are accessible from the getter methods. * `getWarns()` - Returns a list of warning messages that were encountered during the edit. * `getErrors()` - Returns a list of error messages that were encountered during the edit. * `getInfos()` - Returns a list of "info" messages that were encountered during the edit. These messages represent normal logging events that occurred during the edit, and can be useful when trying to visualize the events that lead up to a failure. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # Retrieve the user we're going to edit. userToChange = system.user.getUser("default", "george") # Make a change to the user. In this case, we're adding some contact info. contactInfo = {"email":"ignition_user@mycompany.com","sms": "5551212"} userToChange.addContactInfo(contactInfo) # Edit the user. Because the user object we're passing in has a user name, the function # already knows which user to edit. system.user.editUser("default", userToChange) ```
